Have no check engine system
Featured Build Threads
Canada AB
I have a 87 ranger xlt 4x4 2.9litre
Running a bit rough at idle was wanting to check for codes
But there is NO check engine circuit
Like not even a pin/wire to create a circuit
I'm not sure what I can do for codes without a check engine light
Has anyone seen this before?
I'm thinking it's my temp sensor not letting the ecm know temp of the engine so it stays in warm up mode
Up to a certain year Rangers did not have a dash light (my 86 doesn’t either).
You can pull codes manually using a test light or volt-ohm meter using the method shown on this page:
If youre looking for the plug its in the engine compartment back by the firewall, passenger side. Theyll be a big goofy looking plug and a small single one. Pretty hard to miss, looks like a short pyramid with a flat top.
Get the code reader. I got one, much eaiser then other methods and worth the 30 bucks. They are on amazon too.
Awesome thank you very much I'm going to see what I come up with using those methods
ECT(engine coolant temp) sensor was added to fuel injected engines so computer could run Choke Mode on cold starts
ECT is always 2 wire 5volt sensor
Not to be confused with the 1 or 2 wire 12volt Temp Sender used since the 1940s for dash temp gauges
Carb engines, even with computers, had a Choke Plate for cold starts, can't use a choke plate with fuel injection, no Jets to suck in extra fuel from
If ECT, IAC Valve and computer are all working, then on cold start engine RPMs should be above 1,000rpm at idle
Then as engine/coolant warms up idle will slowly drop, "target" warm engine idle should be set after 5 to 8min depending on outside temp
650rpm on manual V6, 750rpm on automatic V6
Choke Mode causes computer to run a Richer fuel mix and higher idle
If ECT was the issue then engine would run poorly until it warmed up, no choke mode
OR
Engine would run fine cold then run poorly after warm up, choke is still applied
Yes thank you I now understand all of that
I'm waiting on parts
Air/charge sensor
Coolant temp sensor
Coolant sender
I've tried testing for codes as per what the others have suggested but no luck
Tried with a multimeter and just a test light
Gives no codes with test light the light just stays on with no change
I thank you for all this info
I tried both methods and got nothing
Double checked to be sure I was hooked up properly with the test light the light just stays on no flashing
Kind of a bummer as I was hoping to get some codes
Take a pic and post of how you hooked up the meter/light.
Event Coverage
Featured Ranger Based Vehicle
