- Jan 27, 2010
- Canada Eh!!
- Automatic
Though this was worth checking out.....Pulled this from the net.
UHMW-PE can be hot-formed on the job to make simple bends and angles that facilitate installation. No matter which method is chosen – torch, electric heater, oven or bath – caution should be used and every effort made not to overheat the material. UHMW-PE, like any plastic, will burn under improper conditions. In addition, the complete cooling cycle will be somewhat longer than the heating cycle due to the high heat retention characteristics of UHMW-PE. Cooling should not occur on concrete or metal surfaces because the process will be too rapid and may introduce additional stress into the material. An additional recommendation is to cover the material with an insulation blanket made from a material such as fiberglass.
This link: http://distributionbizwiz.wordpress.com/2007/08/22/fabricating-machining-uhmw-pe/
Interesting read about uhmw.
