Front passenger side axle shaft seal on a dana 60 f350
Dirtman
Former Middleweight Moss Fighting Champion
41N 75W
2.3 (4 Cylinder)
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
Any trick to pulling the passengers side axle shaft seal out on a 2003 f350 dana 60 front? That bitch is deep in there and I don't wanna pull the stupid carrier to do it...
Never tried it on a dana 60 front inner, but it might work. I screw in some self tappers that are small enough to catch the metal rim and go in just enough to get a bite, and use the screw heads as pry/pull points to finagle it out. Otherwise enough dremel slices to mangle it out.
"Don't force it, get a bigger hammer."
The seal is approximately 3.5’ down inside a 2.5” ID tube.
I've decided to ignore it and pretend it doesn't exist. I'm not pulling the effin carrier...
