susieranger
- Nov 29, 2007
- '92
- Automatic
I overhauled my front brakes ('92 2-WD) a few weeks ago with new rotors, calipers/pads, and bearings/seals, and today I suddenly started hearing noises from the front right rotor. I pulled over, jacked it up, and the wheel moved up and down like the bearings are out. I opened the grease cap and saw a bunch of black looking grease instead of the pink grease that I saw when I looked it over and double checked our work last week. Does anyone know if it sounds like the seal broke to cause this problem or does it sound like something else could of happened? Maybe we torqued it too tight to cause the problem? I can see that the outer bearing is gone when I took the spindle nut off. The washer looks like it's kind of frozen and I haven't had a chance to try and break it free. I'm 300 miles away from home right now and needless to say I'm not going to drive it until I figure out what to do. Thanks very much for any help.
Susie
Susie
