Fants truck
Yea il post sme pics later today. I no longer have motor hoist. (Borrowed frm friend)so im contemplating on safest way to lift motor. Im hopin 1/4 inch will be shimmed enough. But ima work on it after work today
Floor jack and a piece of wood under the old pan.
Sent from my SPH-L710 using Tapatalk
Don't jack on the bottom of the pan but on one of the side rails. Doing it on the bottom can close up the distance from pan bottom to oil pick-up enough that you might starve the pump for oil.
Dave
Not all in the center but a large enough board that covers the entire area of the bottom of the pan. If hes going for 1/4 inch then not much should be moving up with the engine.
Also did you go with the Taurus fan and if so what wiring setup.did you go with and whatnot?
302 is in
Attach Files
Valid file extensions: doc gif jpe jpeg jpg pdf png txt zip
Oil pan touching crossmember. Needs shimmed
Attach Files
F150 fead
Attach Files
92 ford explorer rad. Had to cut to fit
Attach Files
Lower rad hose
Attach Files
Tcase and tranny. Needs touch up paint after install
Attach Files
Pic of shifters. Guage install. Workin on dash guages
Attach Files
Attach Files
Attach Files
Attach Files
Attach Files
