smile661
- Mar 9, 2011
- Automatic
Hello, i have a '96 Mazda B4000, it has the 4.0 with auto trans. I unbolted the exhaust from the cat-back. I then made myself a short tube with a 80ish degree tip bend pointed downward. It sounds good for what it is but i have no intention on leaving it that way. I had very little tube to use so it is still under the cab. I will be getting a muffler shop to cut/bend me a piece so that i can have a more proper exhaust. I am debating whether to stay with the stock size tube, or go larger to say a 3 inch. It will run to the front of the wheelwell where it will then have a 45 degree tip bend. or it will exit to the side in front of the tire. Either way i dont know whether to put a tip on it or what kind. I would like to hear form you guys and see what you have to say.
