- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
yep, I asked the guy at the counter for one for a manual tranny '86 turbo coupe... that was with my discount though... rockauto.com was about $105 plus shipping
back to my parts score... The guy found some more stuff and wanted a little more cash, so for $240 I got:
-2 turbo engines, one missing exhaust manifold and fuel rail and a few other things
-2 VAM's, a small and big, the small one is toast, the bearings are sticky and there's corrosion in the sensor...
-3 lower intake manifolds, two upper (total)
-4 ECM's, 1 PC1 (eliminated that as my problem already this evening), 1 LA3, 1 LA and an 8SE (I'm guessing auto tranny)
-One of the engines has a T3/T4, there's zero end play but the exhaust housing is cracked...
-also the volvo turbo in the picture and the two intercoolers...
-two COMPLETE turbocoupe wiring harnesses, and I mean complete, one has tail light connectors and the stereo amplifier...
I'm going to go through all the parts after I get back from my trip next weekend, I know I'm going to build up a spare engine
on my problem,
-when it's happy it runs pretty good, weird things only happen under boost, usually will run better if I hit it then let off quick and get back on it. It sounds like a misfire, kinda fluttery and rich sounding. The other day when I said it was getting bad mileage that was mostly freeway driving at 65ish, first freeway trip on the new gears and 35's, at a high load is where this is running funny so that's why for whatever reason.
-when it's unhappy it is only when it wants to and only on hot restarts it will fire right up, but if I don't catch it before the vacuum goes below like 10" HG and put it at about half throttle or above it will not run at all, I shut it down for half an hour or so to try to get that VAM working to try something else and it ran fine again...
ran a KOER test and it kept dieing when it went to check the EGR, realized I hadn't reset the idle since I fixed the wiring, now I only get code 34 on that test, and 67 on the KOEO test.
I put on the replacement PC1 ECM after I got the second engine unloaded from the back of my truck, started it up and it did exactly the same thing it had done to me last weekend, so it wasn't that. Would the idle not being set properly affect that any? I haven't driven it since I reset it.
Does the throttle position sensor have anything to do with fueling? the type of sensor on these engines doesn't look the most hearty with wires just sticking out of it and not a connector on the sensor itself, I want to replace it but don't know how to reset it, probably find that on a quick google search...
I now have all of the parts to upgrade to the sought after LA3, but that requires a fair amount of changes that I'm not prepared to do in the next 4 days... in a couple months I'll rip into the thing and fix it's numerous leaks and clean it up and upgrade then.
I know I just wrote a book, but if anyone has any ideas it would be appreciated.
on my problem,
