Exxhaust note of a 4.0L
smile661
10+ Year Member
Hello, i have a '96 Mazda B4000, it has the 4.0 with auto trans. I unbolted the exhaust from the cat-back. I then made myself a short tube with a 80ish degree tip bend pointed downward. It sounds good for what it is but i have no intention on leaving it that way. I had very little tube to use so it is still under the cab. I will be getting a muffler shop to cut/bend me a piece so that i can have a more proper exhaust. I am debating whether to stay with the stock size tube, or go larger to say a 3 inch. It will run to the front of the wheelwell where it will then have a 45 degree tip bend. or it will exit to the side in front of the tire. Either way i dont know whether to put a tip on it or what kind. I would like to hear form you guys and see what you have to say.
I would say that 3" is much to large. I would stick with 2.5". I have 2.5" from the cat back to a thrsh welded dal chamber muffler and it exits in front of the rear tire.
Red Neck rumble....lol That is what we call people here who do that!!! Too noisy is not good and can get you a ticket in some areas!!!! It might cost you hp and gas milage drop....just to it the right way, Bro!!
Haha, yeah i know. I'm not one to usually do this, but i just got the truck and will be using it as a run-around vehicle. I dont wanna put any money into this truck, and i am moving to a new area soon where i will have to put the stock muffler on to pass safety. I like to work on stuff so i have been tinkering on this truck. The only reason i was thinking 3 inch was because there'll only be a few feet of it and i thought it might give it a little deeper tone vs the 2.5". I could probably get both and just experiment, thats waht i've been doing so far.
