Escorts 2nd SAS
Yup I'm getting there, I have most of the stuff now. Still need to rebuild the axles and graduate college.
I still want to see this solid front axle Escort.
Lol. I posted a picture of one somewhere in this thread.
Anyways, I've been having problems with it running. Last few weeks its been getting worse, when cruising at in 5th gear and slightly accelerate it wants to start hesitating. Its kind of hard to describe, it wants to start sputtering and bucking?:what: the more gas I give it the worse it gets. It does it more when its at operating temp but also does it when its cold. Not sure if its fuel or ignition related. Anyone have opinions?
Sent from my HTC ONE using tapatalk 4
Even though mine is carbed, it has been doing the exact same thing the past few weeks when mine gets to temperature and when I hit 4th gear and try to give it gas, just has no go anymore.
Sent from my rooted SPH-D710 using Tapatalk 2
how old is your coil pack?
edit: Btw thanks for a great build thread. hopefully by the middle of november my truck will be done with pretty much the same set you are running. this thread is full of great info.
That's a good question. The previous owner took excellent care of it and regularly had it maintained at the dealer. So it could be original or as little as 3 years old.
Thanks, I'm glad my build helps inspire others.
Could low fuel pressure have anything to do with it? The pump has been sounding....well....odd last few months
yea if the pump isnt keeping your pressure up but it could be it. kinda weird tho most of the time fuel pump just shits out. I cant think of a time that i ever say one that worked but didnt build enough pressure when i worked at the dealership
edit: isnt there a test for the coil packs?
Well. The noise it makes at times when key on priming is a gurgling sound. Doesn't do it all the time though
Mine has sounded like that for years. lol
Mine used run like dog shit when ever it rained or got humid or crossed water. Turns out it was a couple of shitty plug wires, and then the coil pack had a burnt socket on the cyl 5 connection
Sent from my XT907 using Tapatalk 2
The noise the pump makes, could that be the fuel return that I hear?
I just deleted the two cats and it still has the same problem. But, it does sound better.:icon_thumby:
You don't just have clogged injectors do you?
I was thinking that this morning on the way to work.
I'm going to replace the filter and go from there. But first I need to clean all the 2" of caked on mud out of the frame rails. And run some Lucas injector cleaner and see how it goes. But with my short cash flow lately its going to take some time to figure this out.
Sent from my HTC VLE_U using Tapatalk 4
Reading up on why my tbird does the samething, they said it could be an injector hanging up or open all the time because of it going bad or the computer needing replaced.
Best thing to do is take a screw driver and put it up to each injector and listen for the clicking of the opening and closing.
