2.5L ('98-'01) Engine running very lean with NO check engine light(98 Ranger) (2.5L) (manual)
Featured Build Threads
Houston
Hello, my engine is currently running very lean with no check engine codes. Short term fuel trim reads around +35.9%
I ran a smoke machine and found no vacuum leaks.
A while ago it was actually running too rich (-23.4% Short Term Fuel trim )and now it seems to have switched around.
I replaced:
-maf sensor
-iac sensor
-ecm
-tps sensor
-Fuel pump and filter
-Fuel injectors
-upstream and downstream o2 sensor
Also my maf rate reads around 4.11 - 6.65g/s
I've been dealing with this for months now, I would appreciate any help
Update: after running the engine for a couple minutes it now started running rich again
Jumping around from 0 to -21.9%
  • Engine running very lean with NO check engine light(98 Ranger) (2.5L) (manual)
I replaced:
-maf sensor
-iac sensor
-ecm
-tps sensor
-Fuel injectors
Did you find the problem?
Event Coverage
Featured Ranger Based Vehicle
