no. the egr tube isnt just an empty tube. is has a metered orifice inside that has to be exactly right or else your EGR system will recieve too much or not enough flow.
of the two smaller hard lines coming from the EGR tube, one should be on the "exhaust" side of the oriface, and one should be on the "EGR" side of the oriface. this is how a DPFE system works. IIRC, both of those small tubes come off of the EGR tube itself, so the meter oriface would have to be placed inside the EGR tube, between those two smaller tubes. if the metered oriface is at the junction of the EGR tube and the manifold, than one of those hard lines would have to be attached to the manifold itself (this may be the case...i just seem to remember both lines coming from the EGR tube itself).
There is only one tube. What engine are you talking about? He is asking about a 1990 2.3im talking about the two smaller tubes leading from the EGR tube to the DPFE sensor.
Mine looks like Joseph's post. It's actually rattling under higher rpm accelleration. Is it bad inside?
Allen
What I mean is, "is there something inside that can come loose and rattle because that's exactly where the sound is coming from"?
I changed out my valve cover gasket a while ago and messed with that pipe and the noise went completely away. Now it's back. It's been a few years though and this is a completely different engine. And tranny! I'm thinking of removing it over the weekend to get a better look.
Thanks.
Allen
I believe this is what Sludge was talking about. If not, correct me.
that is what i was talking about...though thats obviously a 3.0, all engines will have the same connections (that 2.3 diagram is innacurate).
between those two tubes is where the oriface is located.
