ebay budget boost
you will need an alignment, and 2" of spacers may make the front end unalignable. check out the tech library for some cheap lift suggestions. i would do about 1-1/2" of lift from some washers in the front, and do some lift shackles in the rear.
as long as the tires sit somewhat straight i dont care. I was more thinking about the spacers are they ok quality?
I've had 2 sets of short add-a-leafs and both broke. That short leaf recurves the existing spring pack--then snaps in half eventually.
If those are 2" thick, they will add 3" to the TTB. That may not be alignable, or may require $50 worth of camber bushings.
I would do a 3" body lift and cut the fenders. You could get 35s on if you wanted and not screw up your suspension.
I don't like those because the spacers are not metal.
I would use the Factory Spacers, or stack some washers under the coil perches before using those (the washers will let you fine-tune the height as well).
For the rear, get the Chevy shackles for 1.5-2" lift (BellTech 6400).
