Easy Question: Throttle cable slack adjustment?
Victorymike18
N/A
Hi,
Working on my recently acquired '98 Ranger 3.0L and I noticed the throttle cable has a lot of slack in it. I'll have to check, but it may not even open fully when the pedal is pressed to the floor...
So, at a glance I could not find any type of threaded barrel or anything to adjust the slack out of the cable. I looked at the firewall, pedal itself, and the bracket at the throttle body. All appear to be non-adjustable.
Am I missing something or is that just how this setup is?
Common issue on Rangers, stretched throttle cable.
There is no adjustment but there is a fix and it is simple :)
Google: Ranger throttle cable mod
You use zap straps(wire ties) on the gas pedal end of the cable to shorten it
Excellent, thanks!
Just wanted to make sure I didn't miss a barrel adjuster somewhere...
That would have been way too convenient. The cable tie mod seems to be working well for me. Irritating to install if you have to wear bifocals. I hate working under the dash.
I just did this to my Ranger. Noticeable improvement in throttle response. Almost feels like a new truck!
