Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
As of now, i have the orange, purple and black plugged in from the dizzy to the dura box. the green wire coming from the coil to the dura box (used the stock coil and harness). The red/light blue wire from the 4 wire plug spliced in the the red/light blue on the 2 wire plug. Then the red wire from the coil spliced together with the light green wire from the 2 wire plug, then both spliced in to the red/light green wire on the gray rectangle plug. That's all for the duraspark stuff. I have a large single wire coming from the alt to the drives side. That is about all the wire i have plugged in.
Are you saying the oil pressure water temp and alternator wires are not connected from the 8 wire plug. The big wire to the alternator is the charge wire blk/org , org/ltblu goes to the regulator, wht/blk on mine is not connected it gives you about 8 volts when the engine is running only. oil pressure is the wht/red and red/wht is coolant temp. You need a test light to show you whats happening with the power actually a cheap volt ohm meter is handi to have then you can test the charging system once you get it started also. If the starter worked before you did the conversion odds are it is in the wiring somewhere.
