DTC P0176 FF sensor unplug fix?
dhkmom48
Have the good ole ff sensor code.
I checked for power 10.8v, ground is good, and signal 5.2v at the plug, all within spec.
I have a feeling I have to get a new sensor or more then likely the replicator of ebay.
My question is I read somewhere that the truck will not run with the sensor unpluged, not getting the 5 volt signal to the PCM, but mine still runs when unplugged???
Any idea if maybe the problem might be the PCM instead?
I currently have the Battery disconnected and am going to clear the code and drive it to see if it comes back.
Any ideas or info on the sensor being unplugged and still running?
