- Sep 12, 2025
- Seattle
- State - Country
- N/A
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Manual
Howdy,
New to TRS, will do an intro post with pics of the project soon. Been using the site/forum as a major resource throughout the build/repair process.
Truck is a new to me (april), 1994 xlt 4x4, 3.0 5spd, 260k original motor and trans (to my knowledge). It was in a million pieces from april through august while I picked off various tasks and cleaned 30 years of grime
Shifting has been a bit temperamental, not atrocious, but leaves some to be desired. Bit clunky to shift into 2 & 3, sometimes accompanied by slight grinding when it engages, double clutching and feathering gas helps. Basically refuses to go into first if its rolling, or sometimes "engages" but then pops out. Reverse can take several tries, even when stopped, does similar fake engage and pop out like 1st. Shifts fine with engine off.
Changed the fluid ~300-400 miles ago, old fluid with pretty dark with some signs of wear but no big chunks. Bled clutch w/ vacuum pump 50 miles ago, didn't pull too much air out, but the old fluid was pretty dirty. Did a shifter rebuild/changed the bushings. I can pull the clutch pedal up towards me a few inches (not sure if this is normal or signs of a faulty master).
The problems persist, so I looking for some advice from those more knowledgeable and acquainted with quirks of the M50D.
Is it just the wear on the synchros? Failing master? quirks of the trans itself?
any input is much appreciated
