Dashboard/gage light upgrade
Captain Ledd
Michigan
If you're not making mistakes, you're not learning.
Dashboard is apart and documentation is taken. FAQ on that will be up later
SOME IMPORTANT INFO:
**1997 Ranger - stock colors**
The LED's you need to order are as follows. All colors are for a stock configuration for a 1997 ('94-current dashboards), and will probably look janky unless you also change the faceplates. The color filter (I'm pretty sure) is part of the gauge faces.
$0.79 + $0.60(green extra) = $1.39 apiece
The 194 replacement series: 6 Green ones, 120° viewing angle
FOR THE REST:
#74 LED bulbs - These are what things like the seatbelt icon and turn signals use. Order ONLY the "74-x LED Bulb". NOT "74-xHP SMD LED Bulb" OR "74-xHP3 SMD LED Bulb" as they will probably blind you.
$1.19 apiece - all colors
For the stock Ranger cluster you need to order these:
GREEN = 3
2 turn signals, speed control
AMBER = 7
4WD, 4WD Low, O/D off, Airbag, ABS, Check engine, Fuel reset
RED = 5
Brake, Seatbelt, Door ajar, check gage, Battery
BLUE = 1
HI-beam symbol
If you have an antitheft system factory installed the "THEFT" light should already be an LED, it should be fine, and I hope it is, because I can't fine a replacement for it besides a Ford Dealership. Not like its ultra important anyway. - this has to be red, the filter on the gage faces is actually clear.
ALTERNATIVES:
You can always order the above style bulbs in a white color. It should produce a similar coloring to that of the standard bulbs.
However repacing them with LED's of matching color will both brighten and increase the quality of light. The "lens" or filter or however you want to put it will only let light out of that particular spectrum. In the Rangers case, predominantly green, so only the green part of the bulb's light produced actually gets out. With a colored LED, the vast vast majority of the light produced is in a specific spectrum (a green LED produces almost ALL green light, it isn't filtered), they only color the plastic because it makes them easier to identify what color the LED is, so basically ALL of the light produced by the LED is able to make it through the green filter (because remember the filter only lets green spectrum light out) giving a much brighter and more vibrant color.
And I think that about covers it. Hopefully this help you all out, because I thought they were all 194 series. Faq will be up shortly, it's actually not that bad, I thought it was going to be much worse.
I have an '84 back home which I have to take apart yet again because it now doesn't light up at all... I can get pictured and documentation of that one too. It's kind of bastardized, but all the spots are still there. I do not have access to a Gen 2 dashboard.
Original Post:
I posted the type, amount and colors of all the bulbs nessecary on Pg 3. Not all the bulbs are 194 series replacement! Only 6 of them are.
I threw these out there on a topic in the lighting forum. I personally have not tried these yet, but I will be replacing every single light with these guys once it gets warmer out. LED's last a crap load longer than incandescents and use less energy taboot (every little bit helps right?)
Some excerpts from the page and other parts of the site about these:
^Clicky on the picture^
**These are plenty for a Gen 3 Ranger dashboard. Anything brighter will likely blind you.**
direct swap for T3-1/4 (#194/168) filament bulbs
^I'm told Ranger dash lights are #194​
Inverted cone clear lens causes the light to emit from the sides as well as the end.
^So there won't be blinding beams of light through your cluster​
Built in current limiting resistor and diode to protect the LED from reversed polarity installation
The resistor keeps the LED's from getting too much amperage. LED's only work with current flowing one way, if they don't light up, flip them around and they should work fine (thats all the reversed polarity instillation part means).​
These LED's will also still work with your vehicles stock dimmer switch.
The Frequently Asked Questions page has some more info on them.
Other applications Include: dome lights, instrument cluster, interior lighting, license plate, side markers, warning indicator, cab top markers, ashtray, courtesy lights, gaming lamps, etc...
And they have much more on that page for automotive applications and even more on the rest of the site.
Main site page: www.superbrightleds.com
UPDATES:
Update. I got the LED's installed today, kind of a pain because apparently if everything is all good when you turn the key and the vehicle performs it's bulb check, they don't light up. I.E., if the door is closed, the "door-ajar" light doesn't light up. Which technically it isn't supposed to, but during the bulb check they're all supposed to light up, regardless it everything checks out. So some of the bulbs I have to find a way to force-light them to see if their in right.
Another thing, replacing the #194 bulbs (the ones that light the main areas up) if you put a white LED in them it glows BLUE, it's not a bad blue, but I was expecting green. And they're not blue LED's, checked that. There is actually a blueish filter that I can see on the back of the dashboard. So I'm betting the yellowish/amber glow from the incandescents filtered through the blue to make green. I've sent a e-mail out to my lighting buddies who did stage lighting for the plays at college, I'll update this later.
Otherwise everything looks pretty good. nice, vibrant and crisp color.
Alright, since I didn't realize that there is a BLUE filter on the back of the Rangers gages and NOT a green one, you do in fact need to shine a yellowish light from behind it to get it to show up classic green that everyone knows and loves.
Since there is a flat shipping charge for orders under $100 at superbrightleds.com, I'm waiting to figure out what our other flashlights take and order those bulbs as well (not to mention setting aside some dough.)
These are the #194 bulbs that illuminate the main part of the cluster.
in a somewhat reversed image (it's the best I can do) this is what is happening:
Only a yellow light and a (well I guess it's more a Cyan color, but still a blue) filter, and it'll come out green.
it's actually not that big of a deal. these bulbs were pretty cheap and they have plenty of uses elsewhere as lots of vehicles use #194 bulb style bases.
i have some similar lights in my instrument cluster, it makes it look much better when all the interior lighting is the same color. i made mine blue to match my radio
you can use one of my pics if you want to :D
in the 1st gen trucks, dash lights are 194's (or 168's, the same thing) and my dimmer does not work like it used to. you really cant tell any difference between full bright and full dim. theres some difference but very little, hardly noticeable
it looks like I may get to mine in the next few weeks. My project Ranger is actually nearing completion (for this stage) which means that I can cruise it back and forth to school and tear into my '97's dash and not have to worry about getting it back together in one day. my heater has decided it only has one setting as well, surface of the sun. So it makes the invasiveness of tearing the dash out more worthwhile.
Interesting about the dimmer switch, but at least I know they won't be blinding or super bright in only one spot judging by your pics.
did this to the escort...havnt gotten around to opening up the trucks dash to do the same. the dimmer functions per norm in the escort :dunno:
dim spot near the 60MPH mark is by design...it did it with incandescents too.
also used white LED's in my dome light after upgrading to a triple beam. the map lights are 194 LED replacements and the center dome light is a 1-watt LED festoon bulb replacement. this setup is quite bright and quite bluish/whitish in color...i like it.
Changing the colour of the dome light might make it harder to read things at night because it strains your eyes. I heard the best light for reading is like a yellowish light from normal bulbs because the eyes don't strain as much like creating contrast and stuff. That's why you don't have blue lenses in any goggle or lens systems. But hey it probably looks cool and its not like you're reading novels in your car.
The inverted cone LED's are great. I've got them on my bike and couldn't be happier. Bought them from superbrightled.com as well.
The benefit of the inverted cone type is that it prevents "spotlighting" of the gauge face.
Yeah, yeah, it's not a Ranger.......
[/IMG]
your right, i dont make a habit of reading alot in the truck. the center 1-watt LED is much brighter than any of the standard incandescent bulbs...so eye strain is less no matter what the color....and i personally find reading in a bright white light much more comfortable than yellowish incandescent glow.
i can see red or blue LEDS causing problems...but i think the white ones are nifty :icon_thumby:
just my .02 on the subject though.
well since youre all sharing pics...
I don't have any pics but I put the same LED's form the same place in my Mustang and Ranger.
The blue is VERY sexy indeed.
How the hell do you guys do that? I don't even know how to get into the dashboard. Do I have to get those ones? Couldn't I just get some blue LED lights at Autozone or something? I really want to change to blue LED lights, because it makes the dashboard look way newer and better. I'm tired of the yellow lights that older trucks have.
Just buy the LED's from that website. They already have the correct resistor and a diode. PLUS they plug right in....
I got 20 or so for $14.
Make sure you have them in the correct way (polarized) before putting it all back together.
Ok thanks.... now how do I get into the dashboard? That's one of the few things I've never know how to do on Ranger/Mazdas...
I'm so confused on which ones to order. My friend has a '94 B4000 with the older dashboard, and he wants the blue LED lights as well... Anyone want to tell me exactly which ones and the quantity that I need please???????????
Thanks!
