I doubt that is an early Bronco 44. It looks too wide for that. One way to tell is if it is a low pinion axle, then it more than likely has the weak u-joints.
You can, but you will have to weld on all the brackets for it. If you do that, you would be better off getting a long arm setup for a XJ and using it (it converts the 4 link to a 3 link radius arm setup). You will have to weld on a coil bucket, track bar mount, lower link mount, and upper link mount.the guy got back to me with some info, he said it is set up for leaf spring Z(spring under) setup. is it still worth getting and is it possible to convert to coils and radius arms?
i dont mind welding, i just want it to be as close to a early bronco style axle once its done, its probably easier to just use leaf springs and welding the perches on the top of the axle and be done with it.
Don't use leaf springs. You already have a coil bucket and coils are really nice for on road/off road use.
I think you can get weld on wedges. I would just find a Bronco 44 instead or get a 44 out of a coiled Jeep.
