Buy quality wheel bearings, install them properly, and you should NEVER have a problem with them. I'm running 35s and flog the living hell out of my D35 (bent two driver side beams in 3 trips) and have never run into a wheel bearing problem.
I agree with the others, there's no reason you should be going thru bearings like that, something's wrong (my D35 still has OE bearings in it from '94 when the axle was originally under my Ranger).
Are the Timken A37s a bearing set? (Race + bearing)? You aren't mixing up races & bearings are you? (such as using the chinese races that are often pre-installed in rotors). How much wheel offset are you running? (or what size wheel & backspace)?
man those statements need qualification.
i cant even come close to agreeing that the d35 bearing setup will hold any 35 in tires trouble free. light radial 35's are doable with increased maintenance. heavy 35's no way. in hard stop conditions the brakes cook the fawk out of the grease.
the offset of the wheel tire type and actual miles and driving conditions are the variants that make these suggestions out of place for me.
granted i run over weight as well, the d35 required constant attention. and often they are improperly setup and maintained...but setup was not an issue for me.
4x4 junkie considering i usually drive more miles in a year then your bearings seen from 94 to 2009, i can say for sure the d35 setup sux ass for big tires. a set of bias 35's driven to the wear bars in one year in city traffic will eat 2 sets of bearings easily. at least...if you consider if you have to grease wheel bearings more then twice a year especially if the thing never was over the hub in mud in 25-30k miles....something is wrong.
its asking too much of them to run 10 inch wheels and 35 in bias ply tires.
so light 35's on sane wheels are one thing.
swampers on typical 10 on wheels are another.
where you drive, how much you drive, how much you weigh are key.
if you want ruthless 37's and setup some 488 gears running the ttb 44 knuckles or f150/bronco abs spindles and outer stubs are a worthy investment if you want to stay narrow as possible.
though using the f series abs spindles required custom parts for the brakes that are simple to fab with 3/8 plate to use the big calipers.
