Cruise control
1994xlt
Forum Member
Morton
IL - USA
Vehicle
Drive
Stock
Stock
good question
Hey guys, trying to get my cruise control working. It’s a 1994 ford ranger Okay so the brake dump valve is taped and I moved the plastic piece so it makes contact. I tested the servo with the vacuum line and of revved up to the moon holy crap. It works. I have looked at the buttons not sure what all I’m looking for but the wires look ok and no obvious corrosion or problems. So is the next step to look at the module? The module looks like a pain in the Yk what to even get out.
So if you took the dump valve out of the equation, you still need to look at the electrical switch on the brake arm. You will have one that does the brake lights like every other ranger, but you will then have another added one to tell the cruise to drop out when you touch the brakes. Like the dump valve, if that is not adjusted correctly it can hold out on the cruise function.
When you get it sorted, try to get the dump valve working again. If it's not working, when you touch the brake the vehicle speed will slowly drop as the vacuum in the servo slowly bleeds off. If the dump valve working the throttle drops back much quicker.
Cruise control
I don’t think my dump valve is messed up. It should be working because I have the black plate up against the valve all the way
If the dump valve was not closed if wouldn’t rev up the engine right?
Guys I got the module out of my truck and the circuit board looks to have a little corrosion on it.
  • Cruise control
With the servo unplugged, the board is out of it, does it still rev the engine? The engine should not rev if the truck is sitting still. If it doesn't rev anymore, I think your circuit board may be suspect like you are thinking.
I tested if the engine revved by bypassing the other end of the servo so it just made sure it was mechanically working I don’t think it’s electronics working
