Fairlaniac
- Dec 8, 2007
- Age
- 65
- Denver, PA
- 3.0 V6
So when will Ford get it right? The transmission cross member bolts are rusted fast to the steel sleeve inside of the bushing. The sleeve broke from the rubber and just spins. I've already gone through this twice this summer. On my '66 Fairlane the sleeve in the leaf spring bushing was rusted fast so I had to cut the bolts on either side of the mount and drop the spring, then to replace the bushing and use new bolts. Same thing last month trying to help a buddy do his leaf springs on his '67 Mustang. Now the damned Ranger. How can Ford not figure out a better way in over 50 years use of the same design.
Well so much for my rant. Any better idea on the Ranger? There seems to be a layer of rubber against the inside flange that the cross member mounts to and I cannot get my sawzall blade in between to cut it. Short of a torch or grinding off the entire bolt head, is there anything else I can do? I'm tired of this crap!
Thanks!
Thanks!
