- Aug 31, 2024
- Florida
- State - Country
- FL - USA
- Drive
- 4WD
- 4.0L
- Automatic
This is gonna sound really bad, I know...So over the past two weeks or so, I've had a burning rubber smell coming from the engine bay, with VERY occassional smoke coming out from under the hood. It smelled extremely strongly of burning rubber, and considering that I've been having belt trouble for a good period of time now, I pinned it on the belt occassionally slipping.
Well, tonight I was driving and it starts overheating. First time it's done this, and I noticed the instant it moved past normal operating temp. I was very close to my destination, so I limped it there. The temp guage was bumping around a lot, and only right at the end before parking it did it bump up to just below the red line on H.
I opened the hood right away, and smoke was coming out from under the throttle body area in the dip between the valve covers. Checked underneath and coolant had dripped onto the front crossmember pretty bad as well as onto the ground. Tracked the leak down to the t-stat. Lots of coolant sitting down in the recess in the block under the intake manifold and behind the t-stat, which is I believe exactly where the smoke was coming from (smoke was colorless and did not smell, btw). The t-stat was fairly wet (definitely bad) and wet in the gap between the gooseneck and the lower housing.
Did some forum searching and found that this was an issue others have had. Looks like I should replace my entire thermostat housing with an aluminum version (here) as the current one is bad and leaking, and seems like it's a pain in the ass to get it to stop.
Most helpful post - https://www.therangerstation.com/forums/index.php?threads/coolant-leak-at-thermostat.185902/
Also - https://www.therangerstation.com/forums/index.php?threads/coolant-leak-at-thermostat-housing.172418/
Also - https://www.therangerstation.com/forums/index.php?threads/thermostat-housing-keeps-leaking.183304/
So, my question now is was this sudden overheating issue a culmination of leakage from the t-stat housing?
- Was it that the coolant finally reached a level where it wasn't circulating properly, resulting in a buildup of heat and pressure, causing even more coolant to leak?
Should I replace my t-stat? I'm guessing a very strong yes here.
Should I be worried about any other issues?
Also:
I need to get my truck back to my house. It's not far, about 2.6 miles. Should I be able to fill the rad back up, get it back (carefully watching temps), without causing further damage?
Bottom line is I cannot leave the truck where it is now for more than tonight, but I'd rather just drive it back than tow it if it's gonna be safe to do so.
Also:
