88fordRanger
Before I start, sorry for the long story!
Okay... Ever since the miles rolled over 200k, I've been having a bunch of problems... I've been losing coolant pretty rapidly lately but just in the last couple days have i found that there is slimy coolant/oil in the oil filler neck on the valve cover... Within the past couple weeks I've had to fill up my coolant like every 3 days or else I run out completely... The temp needle has never gone above 3/4 hot (even the 2 times i found that there is no coolant at all in the radiator.)
So there is coolant in my oil but no oil in my coolant...
Now there are a couple things it could be. I'm aware of the weak head problems on the '88 2.9's, but could this cause the coolant in oil but not oil in coolant? Is it likely, since it's never been overheated in its life (according to the needle)?
I would think the head gasket is more likely the problem...
There is another gasket that looks to be the timing cover gasket or something (my dad pointed it out) and it's wet around the edges of the gasket... It looks like it goes up to the heads...
What else could it be?
I haven't taken the valve covers off because I don't have the $15 for new gaskets or have the few hours to do it... plus I just replaced them no more than 4k ago...
P.S. I have no money and little time to do the head gasket or especially change the heads...
Is there anything I can do to make it last until summer like a month from now? Is there some product that will clean up the slime and slow the leak? I thought of just changing the oil a lot, but it wont get the slime off the top end of the engine... I think by the time I'm half way through summer I'll have money for a 5.0 swap which i think would be more worth my money than rebuilding a 2.9.
My dad who gave me the truck a year ago is really getting pissed at me because everything is going wrong and he thinks I'm beating on it... But it's 24 years old with 200k on it and everything is original.
Need some tips to make it last and I'd like to know that it's not completely my fault... It's partly the age of the truck, right? My dad's making me feel like I'm killing my truck lol....
Here's a pic of the inside of the filler neck... I tried to wipe out most of it that i could reach down the neck.
