conversion help
mobile madness
Virginia
Found a m50d in a jyard for 180 bucks. It was in a 98 supercab 4x4 4.0 and I have a 91 4x4 4.0. What else am I gonna need beside the steering column, cluster, ecu, clutch pedals, flywheel, master/slave cylinder?
Will any brain out of a 4x4 manual work because the brain I pulled is different than mine.
Also how can I replace the slave? I unbolted the two bolts but its sticking out of the hole so far I can't remove it.
