5.0 AWD to 4x4 conversion help
The problem is the linkage is attached to the transmission, and people don't expect others to be modifying things and doing odd swaps, they expect you just need a transfer case because the old one is broken... not because you want your 4x4 to work when you expect it to... :). This is the beginning of the manual transfer cases going away, so they aren't very common as well so it just adds to it...
I guess that makes sense, still would expect somebody to carry replacements...oh well, guess I'll keep looking
linkages don't break often, so they don't sell, so they get torched when the tcase is removed
Well that's just a crying shame
PJ I'll check that link, thanks!
Manual transfer cases were pretty much gone in the late 1990's same as manual transmissions
Both became Pay Extra Options, and by mid-2000s were not even offered/available as an option, lol
So the OEM shifter spare parts were used up long ago, and there is just not enough demand in large enough numbers for a 3rd party to replicate them
Behemoth Drivetrain made an electric to manual shifter that worked on any Ford BW electric transfer case, thought it was a great idea
But not enough of a market so they stopped making it
EDIT: they still make it but pricey: https://behemothdrivetrain.com/product/borg-warner-electric-to-manual-shift-conversion-kit/
Even the Shiftser died out because of limited demand
Hi all, I have been trying to identify what all I need parts wise. I have a '97 Ranger with a '96 Mountaineer 5.0/4R70w/AWD tcase. I have the 8.8 rear end and Dana 35 TTB front end. I got this truck without any of the 4x4 pieces forward of the tcase. So, I want to keep the auto, but swap the tcase to a manual shift BW4406 with manual hubs. I have a 3" body lift so far, but will be going with the James Duff 6" suspension kit. Ideally I want to get rid of the body lift, but I can keep it, or go to smaller one if I need to extra space. So far, as I understand, I need the BW4406 out of a '97-'03 F150, and the driveshafts, along with Ranger driveshafts to build hybrid driveshafts. So I guess I'd like for some advice, or better info on what I should be looking for, as well as locating a front differential/axle shafts. Thanks!
O would like to put a AWD into a 4x4 1990 Ranger
