- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
I just swapped a rear from a '87 ranger to my '85 b-II. The perches on the ranger were in toward the center by an inch on each side. I welded a 1/2" thick 2 1/2" by 5" plate [to the perch] offset by an inch [with a hole to match the spring bolt pre-drilled]. There is a new rear u-joint on the stock double-carden shaft. It seems to be working fine but I think I have to clock the rear because I added a 2 1/2" block at the same time,and I'm getting a vibration at ~ 110 kmh [68mph], and it gets worse the faster I go. So is that the problem or should I look at something else? From my research, i think I'm supposed to aim the pinion center line at the tranny. So is there a flat area on the axle that I can use to aim the rear at the tranny? And where is the aim point on the tranny?
Thanks,
Richard
Thanks,
Richard
