Clock rear after adding lift blocks?
alwaysFlOoReD
Airdrie, Alberta, Canada
'06, '11
I just swapped a rear from a '87 ranger to my '85 b-II. The perches on the ranger were in toward the center by an inch on each side. I welded a 1/2" thick 2 1/2" by 5" plate [to the perch] offset by an inch [with a hole to match the spring bolt pre-drilled]. There is a new rear u-joint on the stock double-carden shaft. It seems to be working fine but I think I have to clock the rear because I added a 2 1/2" block at the same time,and I'm getting a vibration at ~ 110 kmh [68mph], and it gets worse the faster I go. So is that the problem or should I look at something else? From my research, i think I'm supposed to aim the pinion center line at the tranny. So is there a flat area on the axle that I can use to aim the rear at the tranny? And where is the aim point on the tranny?
Thanks,
Richard
Why did you install a NARROWER rear in a Bronco2 when bronco2 rears are so common?
If you were willing to do welding you should've used an EXPLORER rear...
AD
Using an 8.8 from an Expo is the better option, but....
Well, what type of rear driveshaft do you have?
Are there two u-joints or three? Or is it a CV style?
I know all my older ford driveshafts were internally balanced and had to be installed properly to maintain balance. If I got the vibration I rotated my driveshaft 1.4 turn then bolted it back in, but most of those were mustangs, worth a shot though.
It's what I had on hand withh the right gearing.
3 u-joints total. 2 at t.c., 1 at rear.
I'll try that. I did alignment marks for the one rear u-joint I replaced.
The only thing that changed was the new u-joint and I added the 2 1/2" blocks, that's why I was thinking that the rear may need clocking. There was no vibration before the changes. The new u-joint has a grease nipple on the outside of one cup.
Edit; and changed the rear end.
Thanks so far,
Richard
Richard
In that case, yes, you need the pinion pointed directly at the TC. At the Pinion, it should be nearly straight
O.K.
Now is there a flat spot on the rear that corresponds[is parallel] to pinion centerline? I have a laser pointer that I could use to help in aiming.
It looks like I want to aim the pinion centerline at the center of the c.v. joint, or is there a more accurate spot to aim at?
Use the pinion flange. If you need, put a square or anything else with a true 90* angle on it directly on the pinion flange. Point this at the transfer case, then go to town.
Usethe pinion flange. If you need, put a square or anything else with a true 90* angle on it directly onthe pinion flange. Point this atthe transfer case,then go to town.
Why yes, that should work! Duh! I guess if I'd thought a little.
Thanks,
Richard
