What did you do to your 2019 and up Ranger today?
I am going to take her in amd have ford do the alignment, trans filter and fluid change, and the 10k service, i suppose. I aimed the headlights after the lift so they dont have to do that.
And i may have to do a 1" lift in the back if she doesn't sit down a bit over time. I tried to find a 2" level instead but no one seemed to have that
You may need your little safety camera adjusted. Guy did mine when I had windshield replaced. Said it should have been done after the lift.
BDS has a 2" front level and Bilstein 5100's are adjustable to 2".
I have a Truxxx 1.5" level.
Got the DPFE sensor on today. $20 from Rock Auto for a unit without the hoses so I saved $100.
It wasn't as bad as I expected to get the hoses off.
No CEL and it wasn't shifting terribly but after a quick run around the block it feels better now.
Installed today:
Front Fox 2.5” struts
SVC Billet aluminum control arms
SVC Billet aluminum tie rods
Vision Nemesis wheels
Yokohama Geolandar MTs
He's talking in the rear. He's already done the front level.
I pried open the old DPFE sensor. Some people have said they found moisture inside. I didn’t, but there was some corrosion so it had probably been wet before.
I had the common missing-paint-on-the-roof-rail and finally got around to masking it off and spraying it with a little Rustoleum.
Got the alignment at firestone. It think it settled a little, finally. Not so nose high
17.25 inches to the top of the step by the back wheel, 17.5 to the top of the step by the front wheel.
Close enough
I am going to have ford check when i get the transmission fluid and filter done this week. It looks exactly like it did when i dropped it off. Like the camber looks the same so if they did anything, it was so little
Are you going to add a PPE aftermarket pan while they do the tranny service?
CMOS
