RangerFella
- Jan 10, 2008
Hey guys...
The "Check Engine" light came on in my 1997 2.3L Ranger XLT (5-spd 2WD, King/Super Cab) as I was pulling away from a stoplight today. It's been raining really really hard for quite a while, if that has any bearing. I went to AutoZone and got the error code and the print out reads as follows:
"Definition:
Fuel trim bank one condition
Explanation:
The [PCM] uses the oxygen sensor to calculate the air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
Probable Causes:
1.-If bank one and two codes set together suspect fuel pressure or MAF (Mass Air Flow) Sensor
2.-Oxygen sensor defective
3.-Ignition misfire-repair
4.-Fuel injector problem
The PCM has determined that during testing, the fuel system for bank 1 was too lean. (Bank 1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank)"
That's all the information I've got. The truck only has 66k on it, and it's a one owner (before I got it) and it's been garaged. I don't know if that really matters but I figure the more background I can give on the truck, the better. I'm going to try the following things FIRST (in order):
-Disconnect neg battery lead
-Run GUMOUT FI/Valve cleaner through it the next time I fill up
-Replace the sparkplugs?
-Replace the sparkplug wires?
-Check/replace the distributor assy.?
-Start replacing other parts (Oxy Sensor, MAF)?
What I need to know is if I'm going about this the right way or if there's something I should know first. If anyone can give me any more information about this situation, like easy fixes or something, or anything else, I'd appreciate it.
RangerFella
"Definition:
Explanation:
Probable Causes:
RangerFella
