BlueLighting1999
how much are you looking for? could do some beltech 6400 shackles in the back, and maybe a coil spacer up front? that should get ya 1 1/2 or so.
whoops. multitasking obviously isn't for me. thought you had a 94 for some reason
Hahaha even though his name is 1999Blue lighting,jk man
is it the 4x4 in your sig? if so the only way to get more lift would either be cranking the T bar or SAS or getting the Super lift as its the most inexpensive lift for your vehicle...
Alright man well Is it a good idea to crank the T bar? What i mean is what are the cons about cranking the T bar? Less handing and stuff. Also what about my rear if i crank the T bar how can i level out the back?
Would Add-A-Leaf do anything towrds the rear?
You should be fine, alot of people here crank thiers. theres a link on how to do it in the tech library, and afterwards get an alignment done. It should be good for 1.5 - 2" inches. And technically the rear should already be lifted as the trucks have a rake to them (front sita about 1 -2" lower then the rear). an Add a leaf would work if you want to go higher out back.
Okay man So if i add a leaf my truck might be a little high in the back? snd your saying not to go over 2 inches wiht the T bar crank?
I dont mean to sound like a noob, but im new with suspentions so can you make a list of parts you need to make your own lift kit? Also What is the differnce between a torsion bar suspension and coil springs. Also Do i need to re-gear if i get a bigger lift, i dont mean tires i mean just a lift?There is no cheap way to lift a 99 aside from the body lift.
Unless you feel like fabbing up your own ifs lift kit. You could do it for $800 in materials and all... I saw some dude do it on r/f... except he had a foreign 4 door ranger... and he left his tbars in the stock location... beautiful lift he did.
Coil springs won't work because you have torsion bar suspension.
Cranking t-bars gives you a lil hight, but reduces your available suspension down travel, and can place extra stress on the cv's if cranked too much.
Sas, used rcd, or superlift are your only options.
No offense, but if you have to ask all that then you shouldn't build your own lift kit.I dont mean to sound like a noob, but im new with suspentions so can you make a list of parts you need to make your own lift kit? Also What is the differnce between a torsion bar suspension and coil springs. Also Do i need to re-gear if i get a bigger lift, i dont mean tires i mean just a lift?
SAS is a Solid Axle Swap. Rip out the entire front suspension and fab up some coil buckets or coil-over shock mounts and control links.What is sas and RCD's?![]()
