Car lift - 7,000lbs
Finally got some progress with the lift.
It wasn't level so I had to jack it up on jack stands. Using the 2x4's that I had attached way back when for the very purpose of lifting the lift. I started lifting. And I bent the bolts... When I welded on the tabs for the bolts I didn't think about the fact the bolts would be above center, and voilà, twistedbthe wood beam. So I removed the bolts and beam and welded on more tabs that had bolt holes near the bottom. Works great, no more twist.
Today I had a friend over and while the lift was up on blocks, we leveled the gravel underneath. Several months ago I was cruising home depot weekly and buying PT deck boards for 75% off. Now I laid them under the wood beams and dropped everything down. Worked awesome. My theory is that this will help spread the load over a much wider area and therefore be much less likely to sink into the ground. The pad prep was minimal as I was never planning on the lift being there. But it will work.
So I'm plumb perfect side to side, and within the bubble fore and aft. Good enough!
Car lift - 7,000lbs
Car lift - 7,000lbs
Unfortunately I discovered a nest in my lift. I'm torn as I don't want to disturb nesting robin, but I also really need to get to work on my vehicles. I'll try relocating them but don't think that works well.
Car lift - 7,000lbs
I started screwing old fencing 2x6 down to level the pad to the white crossmembers. This will also distribute vehicle weight better. Then I laid some 3/4" plywood on top. Now the swing arms are dragging when I move them in... FML! I was dreading unscrewing the 2x6's, as that was a few hours work and would be wasting lumber.
But....
I remembered...
Thus is a lift....
So I can use the lift mechanism to raise the arms to clear the plywood....
Crisis averted!
I never said I was the quickest on the draw...lol.
Got the other side of the platform finished and plywood on. Drove my escape on to test the lift. The fcking arms wouldn't extend! They were rusted in place. So I moved the cat, raised the arms to a good working height, and using a sledge took my frustrations out on the arms. Eventually the stopped arguing and I got them out clean them inside and out, greased and gear oiled, and put back together. I'll test the lift tomorrow.
Car lift - 7,000lbs
Car lift - 7,000lbs
You can see the rust that came out on the ground. I didn't get after pics.
still progress. Success from determination and effort. Sometimes frustrating, but always good.
Okay I googled prefabricated metal garages and they're over $8,000.
The ones I saw were averaging around 10,000.
So I will admit that I was wrong and I would have lost the bet.
The prefabricated carports were averaging between $300 and $500.
I was wrong!
30 years ago it was correctish.
can you get some i beam? or an old trailer frame?
the wood can work but if you make a leveraged base from beam it will be anon thought with changing seasons.
i was getting ready to buy a sidewinder but ended up going in a different direction. really need a lift to do the levels of work with the thing that identifies as a ranger and any newer ford....
I'm here until next year Xmas. So I did it the quickest safe way utilizing material I had on hand. I have an old RV frame I was thinking of using but it would have taken too long. I'm limited in mobility and energy so there is that too.
Looks like Brave and Firefox both have problems with picture orientation.
@Jim Oaks
Perhaps check into the new software and see if there is a setting that needs adjusted. There was someone else saying they had the same problem so I doubt it on our end.
I see that picture as rotated 90* clockwise on Chrome...
I used my lift for the first time today. Got the pinto up about a foot and blew the breaker. Its pretty cold out so maybe the hydraulic fluid is too thick. I gave the car a shake and it wobbled a bit so I decided that's high enough for now. I'll make some jack stands to put under the car before I work under it.
Car lift - 7,000lbs
Car lift - 7,000lbs
Maybe some of those tall stands used for driveline work would do the trick? Not the hydraulic ones, but the one with the jack screws. That way you could get the car up high enough to stand under it and still have it stabilized.
That's my idea. Nearly a decade ago I bought some gear driven jack screws about 2' long. I'll figure out a way to use those.
Update. I moved the pinto up to about 5' and stopped. The posts were starting to lean in.... The ground this is on has not been worked on for use as a driveway or parking. The wood I have under the connecting 2 x 2 beams is helping but not enough. So I'm making a crossover piece up top. Got it about half finished last night. Hope to finish making it tonight and install tomorrow. I measured the space between posts on the bottom and cut a 2 of 12 the same length to push the posts apart to the correct distance. Clamped my walking plank to the lift arms so I don't do a gymastic maneuver. Car is staying as its not drivable so I have to work over it.
Car lift - 7,000lbs
Car lift - 7,000lbs
Car lift - 7,000lbs
Car lift - 7,000lbs
Car lift - 7,000lbs
Pics are not in order... Oh well.
Got the brace finished and half installed. I was able to use an existing bolt hole on the right side. Only one because of the pump reservoir. Tomorrow I will drill and tap 2 holes for the left. It's tight inside the post because of a pulley right where I need to bolt. So I will tap
Car lift - 7,000lbs
in threads and use bolts just long enough.
