- Apr 13, 2009
- '06, '11
- 3.0 V6
A couple years ago I bought a new to me car lift from my boss. It sat at his place until last fall and he got tired of looking at it. He got a couple of the other guys to help move it, I wasn't there. It has a sub-frame that is bolt to poured in place concrete slab about 1.5'x5' by I don't know how deep. The used a couple 1.5" x 1.5" x 1/8” angle to span across the posts at the top. Then used a chain from one post to the other and a fork lift...
The angle folded and the sub-frame bent to crap...
That's how I got it. I was a little bit pissed at the time but in hind sight it was probably a good thing as the sub-frame was pretty rotted.
The last few weeks I've been slowly getting a new sub-frame put together. The only parts I used from the old one were the 2 end pieces, 2" x2" solid bar 55" long. I cleaned them up and welded some 2" x2" x1/4" angle to the top to be used to attach a 6"x6" x10' pressure treated beam. The beam is in place of concrete. It will sit on compacted recycled concrete. The other part of the sub-frame is two tubes, 2"x2"x3/16"x134", which are welded to an I-beam that has been cut in half to form a T. Two holes were drilled to match the holes in the base of the lift and the 2x2 was welded into the opposite side.
Pics and descriptions to follow...
