Can I get some advice on subs
I have to ask this again, can i use dacron as poly fill or would it be better to rip apart one of my older pillows?
When i say dacron im talking of a sheet of polyester fiber, it's used to make fabric covered airplanes and is also used to cover fiberglass in between vacuum sealing the part. It pulls off of the resin because it's one of the only fabrics that won't stick to resin, it leaves a rough surface for the next layer of fiberglass to be placed on...
Anyone?
i used the bags of pillow shit........as long as its light and fluffy.
Whats up guys, I ordered the Polk subwoofer I was talking about, and I decided on the subwoofer enclosure that rjppunk recommended.
I'm all set for when they come in :icon_bounceblue:
...well almost, I still need to find some old pillows to rip apart for poly fill :D
Alright, I GOT THE GOODS... the enclosure, the subwoofer, and a big ol bag of polyfil from walmart :D
How should i put the polyfil in there, should i staple it or glue it? Or is there some other secret way?
The sub didn't come with wiring so i have to get it myself, i like using crimps so im going to find some that connect to the enclosure's terminals... here they are...
BTW, how exactly do i put the wire into the sub terminal? It has spring loaded inserts, do i just slip the wire through or is that secure enough, sorry, I'm still a noob...
yes thats strong enuff
