Bronkzilla - '79 Bronco
in the wheel well/ floor where it rusted through. see how soft it is
it was pretty soft but i beat all the soft parts off with a welding hammer
now what i would do is cut it as square as possible then wire wheel it to get as much rust of as possible, get the rattle can primer and just put a coat or two on till you do the fab work at least then theres a less chance of it rusting again right away
yea i was going to start grinding all the rist off tonight but i gotta work so i gues ill go at her around 10pm, keep all the ideas coming
yes man well ill be goin back to dads tomorrow where the bronco is and the camera is so ill post the pics then
heres a pic, you cant really tell how much drop is in the bedside but its hanging about 2" lower than the floor and the rest of her:
here it is jacked up and level:
and a roofles pic for koda
I wonder if the wheelwell and bed floor from a pickup could be used to fix this, easy to find, just cut out what you need and replace whats bad, I know that the inner box is the same for the pick ups through the 70's 80's and early 90's, might be able to find a box with bad rusted sides and a good inner box if its similar to the bronco
thats alot man i never thought of that, il try to find one. when are you gonna come out to help me with her? haha
damn bud, i bet a lil soap and water would help your cause ALOT. at least see what your workin with and a lil rattle can job.
yea i swept it up and sprayed brake clener over it tonight
and on atnother note, i cleaned out my carb tonight, done a good job cause i wanted it to run as good as it could get, sprayed WD40, then air hose, then WD40, then air hose again, sprayed all the joints so she moves freely now, and i can step on the gas wihtout it dieing!!:yahoo:
right on, if ya do let me know so i can call my boss an asshole and take a couple days off lol
Event Coverage
TRS Merch
