Brake lights
Gordo03
Indiana
2.5 (4 Cylinder)
31”
All bulbs work as should ( turn signals, running light, reverse light )new brake switch all fuses are good what else should I be checking
Is this on the 2000?
I would start at the brake switch.
Parking light uses the low power filament, but turn signals use the high power filament (same as brake) so most likely all (or most, i.e. past where they join) the wiring is good.
One leg of the brake switch is hot all the time (from batt via fuse), the other leg is only hot when depressed (out to wiring harness).
