Brake light problem
DagoVasek
Texas
My left brake light wont turn on. The right side brake light and all other lights work fine. I already replaced the bulb, fuses, socket, and brake switch, Did I miss anything?
Does the bulb light up when you turn the headlights or turn signal on, or not at all? I would check the ground.
It doesn't light up when the headlights are on, the other side does. Turn signal works and reverse lights work. I'll find the ground and check on that tomorrow.
Do you ever have one of those days?
Well my brake light went out, I replaced it still didn't work, checked the fuses, replaced the socket, brake switch, and still nothing. Today I decided to check for a loose ground...or a frayed wire and I took a closer look at the bulbs... well it turns out I replaced the flasher bulb instead of the brake light bulb. ...I tell you...
