- Jun 1, 2026
- Blacksburg
- State - Country
- VA - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0L
- Manual
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 215/70 R14
Been driving my 1993 ranger with the window down since the spring. About two days ago tried to turn the A/C on and nothing came out, no air from the vents. I checked the whole wiring path (doesnt seem there's a lot involved). Worked a week or two ago for the defrost.
There is the always on 10v from the battery present on one of the wires to the blower, and the knob seems to ground the correct wire. However, its like the supply can't push enough current, because it disappears to 0v once the motor is connected to ground. Motor works connected straight to the battery.
Only thing strange about the wiring is a quick-splice connector on the +12v wire which goes somewhere to do with the A/C I believe. The whole A/C system appears to have been replaced at some point because it takes r134a refrigerant and has a sticker saying it was serviced.
I've poked around and tested everything I could reach and it seems like maybe the wire from dash fuse panel to blower could just be bad? Maybe loose or something preventing it from drawing any real current. Nothing is shorted directly to ground as the fuse has not blown.
Two questions I suppose: 1) Where does that wire run from under the dash to the blower across the truck and 2) What else could cause this issue if thats not the problem?
