Bleeding Brakes with ABS
For 800 dollars you can buy one of these if you simply cant find a friend to work the brake pedal. ;missingteeth;
I had enough time to bleed the fronts - I know I should start at the back but time was limited and the left front was the problem. I had to really work at it to finesse the bleeder screws out. They clearly had not been out before, and the fluid that came out was green like pond scum. I think the rears will get new wheel cylinders when I bleed them since the parts are so cheap.
Took it for a drive tonight and the brakes are nice now. No more pulling and no temperature difference between wheels.
