BDS 2019 Ford Ranger 2-Inch Leveling Kit
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
26293
Specially designed for the new Ranger, this 2" leveling kit is engineered for additional tire clearance and improved performance without overextending the suspension or driveline angles at full suspension droop (as is the case with other top mounted spacers and taller leveling kits on the market). The issue with most other kits is they increase the overall length of the strut assembly maxing out ball joints and causing the CV shaft/boot to operate at an extreme angle leading to premature wear/failure of the components. To get around this apparent issue the BDS kit uses a 2-piece design with a smaller top mounted steel strut spacer in combination with a preload spacer. The top mounted spacer installs easily and is finished in a durable black e-coating for a clean appearance. The preload spacer installs below the spring and raises the ride height without extending the overall extended length of the strut assembly while maintaining factory ride quality allowing you to get the most out of your new Ranger's factory suspension.
Also included in this new 2" leveling kit are a pair of precision tuned rear gas shocks to further enhance your Ranger's performance. The BDS NX2 twin tube gas shocks come standard or can be upgraded to the FOX 2.0 performance series IFP shocks for race proven damper technology. Give your new Ranger the extra boost with this 2" leveling kit from BDS Suspension.
Tire & Wheel Combinations
285-70 R17 w/Stock 17" and back spacing
285-65 R18 w/Stock 18" and back spacing
*Trimming may be required*
Est. Installation: 3 hours
Difficulty Level (easy 1 - 5 complicated): 3
http://bds-suspension.com/product?kid=1544H
26294
26295
