85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
Also in my F-150 7700 Series that was hit head on and totaled. The other driver admitted to reaching for his cell phone when he hit me
*That truck held up amazingly!! Look at my truck then look at his car
MY TRUCK
Maybe he was just trying to kill that plate?
The three things to take note of are that a living tree, unlike a stop sign, is much tougher as it has more moisture and is more flexible--a living oak trunk is much more sturdy than a dead piece of lumber. The only reason you dry it is for dimensional stability--you make it weaker when you dry it. Secondly, a living tree has roots that can go down 50', even if it is fairly small, and those downward roots come out of a lot of places--not just a single tap root below the trunk--that tree has a lot of mass below the ground, and going off in a lot of directions--including straight down. Lastly, the mass above the trunk also plays a huge part. All of that mass above the point of impact plays a huge role in the results of your crash. If the tree was only 6' tall, you might run it over. Even if it is only 6 inches thick, it might have a couple thousand pounds above the point of impact--that mass is something you have to deal with if you plan on running over the tree. The net result of it all is that even a semi will be stopped by a pathetically small tree. A small vehicle like a 4-ton dually pickup doesn't stand a chance.
They say that there is just as much tree below ground as there is above as a general rule of thumb.
