B2 seat covers
leseman1
15+ Year Member
Washington
N/A
Vehicle
Ford Explorer
Drive
4.0L
5"
Does anybody make rear seat covers for Bronco II's, I found some for the front but want front and back seats to match.
Id be interested in some too. Camo would be sweet, to match the front ones.
B2 seat covers
I saw somewhere on another sight, where somebody took Plasti-dip, and coated their seats. I tried it with my Explorer center console arm rest that I installed in my BII. (The original color was wrong, and the material was worn out) I used black plasti-dip, and brushed it on with 3-or 4 coats. It ended up looking pretty good, the trick was in the last coat, getting a smooth finish. It will probably last longer than the foam padding inside it, now.
You might not want to do this to your back seats, although, I'm seriously thinking about it for my front seats, now. I want something somewhat water proof for when I have my half doors on.
Incase you're interested in the idea.
Hi,, is Plasti-dip a spray-on dye for upholstery? I never herd of it,,, need to change color on my BII. Ill check at Oreillys and AZ here..Larry.. dang tired of this unusually hot summer,,arg.:icon_cheers:
No, Plasti-dip is a rubber type product you usually use to coat the grips of pliers, tools, ect. It can be purchased in either a can that you dip the tool into, or a spraycan. I have found it at most hardware stores, and some farm supplies stores. It comes in all the basic colors, black, red, yellow, blue, and green, and can be ordered online for special colors, including camo colors..
http://www.plastidip.com/
What I did was use a throw away cheapy brush and brushed it on, rubbing it in, in a circular motion to soak it into the "plush" fibers. It sets up pretty fast, especially in the heat, and repeat coats can be added as soon as it does. I added 4 coats, just to get a nice thick, smooth coating on the arm rest I'm always leaning on.
I also used it in my 85 BII on the inside door panels at the top by the window, where I rest my arm all the time.
The end result is a smooth, rubbery surface similar to naggahide, or vinyl. I used black, because it worked better than the other colors at the store I was in.
I also used the black spray on version on my door mirrors to make the chrome black. I cleaned the chrome surface with window cleaner, and then degreaser, then sprayed on thin layers until it looked nicely covered, and smooth. I brushed on black, onto the mirror support bracket and mounts, I think 2 layers. I have had this on my truck in all weather, and the whole 100+ deg temp summer, and it has held up great.
My interior in my 87 BII is tan, so, I'm thinking when I get the money to do it, I'm going to order tan Plasti-dip, and do my front seats. That way, when I have my half doors on, they will be weather proof.
I used the mossy oak seat covers for my front seats. They are pretty much water resistent. They are about 30 bucks a piece. I'm thinking about using some more with the back seats and just do some creative sewing or take them to an interior shop.
Iv'e tried to find seat covers that I liked, most just look to me like they're covering up something (which they are) but just not a clean all around look for me. I thought about plasti-dipping seat covers, as well, but still the same thing. If I had $$$$ I would have them professionaly recovered, or buy new seats, but alas, I must do what i can, with what I have, mostly.
I found the original material that my '84 seats are made from. It was a good find.
