Axle shaft rubs
Missed leg day
5+ Year Member
Passenger side axle shaft is rubbing on the driver side drop bracket or front bracket 6 inch old skyjacker lift kit everything is tight it sits level anyone had this happen before?
Have you checked the radius arm bushings at the frame. Approx. under passenger seat.
Yeah I did they don't look that bad lol but nothing to make it move that far forward I hope, I will post pictures a little later thing will be the death of me.:annoyed:
Just to be clear;
Your passenger side axle BEAM is hitting the drivers beam drop bracket [mount]? [drivers beam mount being on passenger side]
Sounds like something is bent or out of position.
Pics would help for sure (pics of where it's hitting, the d-side beam bracket, and of the radius arms, bushings and mounts).
I saw 1 picture and I can tell you for sure that the bracket in question is severely pushed back.. it should be bolted and tight to the cross member.
Ok is that the first pitcure? Bec its all ran down tight!
I'm sorry, I will not sign in to anywhere in order to see someone else pics. I don't know how you can make google show your pics. You can load them to an alternative pic hosting site OR you can put them into your "pictures and albums" located in your TRS control panel.
