Mr Independent Wheels
2001 ford ranger 3.0L 2wd automatic (5r44e ???)
My friend bought this truck and when he was driving it home, it wouldn't accelerate as he got onto a ramp. It just revved but wouldn't move. Tried manually shifting to first which didn't work. Tried manually shifting to second and it would work to get moving, then he could shift back to drive and it would run fine until the next stop sign, when he would have to start in second again.
When you shift to first or drive (from a stop) you can feel it engage, and the engine bogs slightly, but there's no hint of moving forward, even with a push to get it rolling. It has diagnostic code P0731.
So we dropped the transmission pan to check for debris, which there was little of. The fluid seems good; not black and burnt. I took the valve body off, which looks quite clean, and the gasket was either torn a little already, or I tore it getting it out, but no noticeable blowouts that would keep it from building pressure. All the solenoids moved when I applied 12V to them, and I think their resistances were in range. The wiring harness was "crispy," and the insulation was breaking off as I bent it around, but otherwise, nothing visibly wrong.
Having seen a YouTube video of transmission disassembly but never having had one apart ourselves, we went ahead and did the right thing and tore it to pieces.
The first one-way clutch(sprag) to come out seems fine. It only turns one way. The bands were coming apart, but nothing crazy. The clutches look new, with no rounded teeth as far as I can tell. There is some noticeable wear on the overdrive planet sun gear(??) in the overdrive/coast-clutch drum. I'll post pics.
Can someone tell me what to do next? I was really hoping it was that sprag but it appears to be good, and the clutches seem good so I'm about at my wits end. Could it just be the wiring harness? Maybe the pump is going out (haven't taken it apart yet)??
Help?
Help?
