Jaydub
- Aug 27, 2010
- Age
- 61
- Wiltshire, England
- Automatic
Hi, My apologies if I'm repeating previously answered questions but I spent most of last night reading through old posts and I'm still confused. Also, because I'm in England I can't just nip out to Peps(?) to swap out a part...
So...'88 Ranger, 2.9 V6, 2wd, auto', bloody good nick, 125000 miles - one of only a handful in this country.
Never had a problem previously, always starts and runs as it should.
Driving home yesterday, severe power loss, trailing a huge black cloud of unburnt fuel. Twenty seconds or so later, cleared its throat and ran clean. A few miles on same story again. Parked up on the drive in Park or Neutral, revved it and it laid down a huge black cloud again, fifteen or twenty seconds later it ran clean. Exhaust is as to be expected, thick black soot. Fuel consumption was around six or seven - I normally get about twenty.
Following advice previously posted on here I checked the vacuum pipe from the FPR (fuel pressure regulator), there was no sign of any fuel leakage into it but it was loose and leaking. I've sorted this.
I fired it up and it started same as always and settled down to a good idle/tickover and did not smoke. Could this leak have been responsible? I'm wary of driving it as I can't afford to damage the cat' or is it too late to worry about that? I've seen in previous posts that it may be the fuel regulator (FPR), O2 sensor, or one of the other sensors - are there any ways to check without specialist kit?
I'm not a total novice - I've rebuilt Harleys, chop's, old Brit' sports cars and hot rods but I'm really a carb's and points man (this is my modern daily) - if this was one of my other vehicles it would probably point to something simple like flooding/float sticking or similar...I've been through the Haynes manual and it was little help pointing to "a fuel or electrical fault" - I'd worked out that much. It states how to remove and install various stuff like the AIT, PCV and MAF but I'm struggling to work out what any of them do...
Also, any replies please keep jargon/abbreviations to a minimum as we really are two nations divided by a common language. Many thanks...
