Keith1985
Well my Ranger came back up with the P0305 code, misfire cylinder #5. I had already replaced the fuel filter, wires, coil and plugs. Cleaned the sensors and all also ran injector cleaner through the gas. So I broke down and took it to Ford. They spent 3 hours checking it out and found nothing. They did want to keep it over night and check "base engine issues", what ever that means, but also says "block test passed" on the bottom of the write up. I had them clear the code but it came back on the way home.
So I guess my question would be, what do I check next? It runs good but idles a little rough, not real bad just not real smooth.
Oh, it is a 2000 3.0L flex fuel.
