AKjeff
Today I acquired a running, complete, 2.3L turbo diesel. It was originally installed in a mid '80's Dodge D50, built by Mitsubishi.
From what I can find on line this is the same engine Ford used in the '85-'87 diesel Rangers.
With some work this will be going into my '93. I have the original bellhousing the PO cut off the tranny, I'm hoping to use this to build an adapter to bolt a Jeep T5 tranny behind the engine. The transfer case is still up in the air, as are the differential ratios.
I think factory engine mounts should work. All I have to do is find room for an intercooler.
I'll try to take pics as I go to post when it's done.
Input and suggestions are welcome.
