Not a lot to report.
I removed from the '87 stx parts truck; front axles, axle drop pivot brackets, rad arms, rad arm drop brackets. Front axles will be saved for parts for my b-II. The brackets are going into my race truck.
I removed from an '88 2wd; front axles. rad arms, rad arm brackets.
I had this idea that I could use the arms from the 88, they are ~ 4" longer, but no go. They don't fit over the 4wd axles. I may still use the rad arm brackets. They don't have a connecting crossmember, so I think I can slid them back pretty much anywhere along the frame rail. If I use them at the tranny crossmember , I'll have to fab a different crossmember setup.
I started looking at the front end of my truck again. Took off the springs and shocks and front sway bar, and am trying to figure where to mount shocks.
Chuck suggested cutting the top shock mount hole bigger to fit longer shocks through it. I also noticed the big trucks mount their shocks on top of the rad arm, I'll see if that's a possibility to do along side of the stock mount. I may also mount two side by side on the side of the rad arm. Another possibility is in front. Three shocks in front would be great!I don't want to lose the sway bar, but mounting a shock beside it may be possible. That brings me to my first question;
What temperature to heat my sway bar to in order to bend it, and then how to quench it? It's been 30 years since I took shop and I don't remember exactly.
I found that my stock brake lines have cracks  may be short so I bought new ones 4" longer; Raybestos: BH38622 BH38623
Cost C$81.00 If I find I need longer when I do the rad arms, I can get extensions later.
I found the front drive shaft hitting the rad arm crossmember when I was fully drooped so I decided to incorporate the drop brackets from the '87. Unfortunately the passenger side rad arm hole is screwed so I got out the grinder. There is a 1.5" block that sits between the crossmember [welded in] and the frame as well as an extension that is riveted and welded to the crossmember. I'll try to remember to take pics.Got one half off yesterday. I hope to get to the rest today.
I got all my springs lined up
These are all stock, starting at the bottom, all looked to have the same wire dia. except the '88; '91 stx ranger 4x4 -single, '79 bronco variable rate under 6350 gvwr -pair, '79 bronco linear rate under 6350 gvwr -pair, d-44 unknown -pair, '88 f-150 2wd w/351ci ext. cab- pair, '87 stx highrider ranger -pair, '91 stx ranger 4x4 -single
I compared the shocks from the '87 stx  highrider to the '91 stx and could not see any difference except the '87 front was longer by 1/2" but same stroke. '87 stx; 14.5" extended, 9.5" collapsed. Probably none were stock.
A comparison of front sway bars;
Left to right; '87 stx highrider 1.156" OD, '85 B-II .989" OD, '91 stx .901" OD
Measurements were taken where the rubber rides. Also notice the difference in the rubber mounts.
Later,
Richard
OK, maybe there was a
little to report?
