A4LD re-build kits
97fordrunner
New Richmond, WI
What is the difference in the A4LD re-build kits for the 85-89 years vs. the 90-up years? Is the newer one the kit that would be built to handle the 4.0 so would that be the best kit to use behind a 2.9? also would all the parts from that kit work the same in the older case and valve body?
Use the kit specified for your year tranny. You run the very real possibility of screwing something up badly otherwise.
