drewrdz
- Nov 1, 2010
- 1994 ranger xlt
One of the most interesting upgrades available for this transmission is the off-road race package. This includes numerous valve body and internal modifications. These modifications are easily attainable from a good tranny man. What this modification does for you, is give you an automatic with all of the advantages of a manual....... and none of the downfalls. Run in drive, you can split the 3 gears with overdrive, and you can lock-up the converter in any of the gears. This gives a much greater availability of ratios, and makes it real easy to keep the engine in its power curve. Also, because you can lock-up the converter whenever you wish, it also helps to keep the transmission cool. This mod also allows the transmission to be used completely manually.
Anyone have more info/details on this? Thanks
