- Aug 16, 2014
- State - Country
- NV - USA
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 4.0L
Ok here we go onto my next issue. 87 Bronco ll 93 explorer 4.0 swapped quite a few years ago. Started running poorly developed a higher than normal idle 1500-1700 found a leaking plenum gasket replaced that along with ISC because it was a little wonky when tested. No weird codes pertaining to engine issues. Sprayed carb cleaner all over, that's how I found the plenum issue and a leaky PCV hose and valve, and fixed that stuff. Now it runs after frame fuel pump replacement but still idles higher than normal 1200-1400 normally idled around 900-1000 for years. Disconnected throttle cable MAF and ISC no change. Checked all around the vac tee removed hoses and plugged connections no change. Have tested the TPS and within specs. Took throttle body off plenum and replaced gasket & cleaned because of a poor connection on the air tube from MAF to throttle body and cleaned MAF with proper cleaner. Sprayed more carb cleaner and no leaks or change noticed. Any suggestions thoughts and advice gratefully appreciated. Thank you in advance.
